Translation from network VLAN tag to each subscriber VLAN tag is done by default in a private VLAN.
configure [ {vlan} vlan_name | vlan vlan_id] add ports port_list private-vlan translatedAdds the specified ports to the specified network VLAN and enables tag translation for all subscriber VLAN tags to the network VLAN tag.
| vlan_name | Specifies the network VLAN to which the ports are added. |
| vlan_list | Specifies a VLAN list of IDs. |
| port_list | Specifies the ports to be added to the network VLAN. |
N/A.
This command is allowed only when the specified VLAN is configured as a network VLAN on a PVLAN.
The following example adds port 2:1 to VLAN sharednet and enables VLAN translation on that port:
configure sharednet add ports 2:1 private-vlan translated
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
